Old Dec 14, 2008 | 08:08 AM
ryan48's Avatar
ryan48
Default smog/secondary air pump failure...how can i trick the ecu...
I have determined it is sadly the pump that went bad. I found a benz pump for the slk 3.2 but chrysler says its a diff part....not sure if it is or not...I'd like to simply either delete it via the ecu or find a way to make the ecu recofnize it as functional. Any ideas?
