Old Dec 14, 2008 | 06:54 PM
70GT6's Avatar
70GT6
Default Re: Making a Cargo Cover. How hard can it be?
The Magnum is 5" shorter than the Crossfire, I wonder if it could roll more fabric into the body if the return stop was not there. Then we could extend or replace the Magnum fabric. I read that it comes in a tan color and the slate grey.
1, Does it look like the same body as the Crossfire?
2, How does it attach to the car?
3, When you say it extends 22" where do you measure from?
From the rear of the bulkhead to the plastic behind the rear lights is about 32" That is about the length we need. Add some more if possible to go over large bags as James1549 suggests.
I think we are getting somewhere, at less than half the price.
Slight differences between them.
The Crossfire cover rolls in tight.
The Magnum and the Mustang roll up and leave a short flap hang. ~4"
Measure taken from whatever was tight to the roller to how far it extended. In the case of the Crossfire it rolls up tight to the bar (no flap, see pic in other post)
They all attach basically the same - the Mustang and Magnum have the slot built in to the plastic panels of the car, the Crossfire uses a separate metal bracket.
All rollers are spring loaded to hold them in place.
