Hey guys just got a new system installed in my car and i am loving it. I chose the viper 5901 remote start/keyless and alarm system with sst which gives almost a mile range.
http://www.dealercostcaraudio.com/viper5901.aspx
we were able to have the heated seats on seperate channels so i could select which one to trigger and it will disable as soon as the car see's the key is inserted into the ignition. I have installed dual sirens in the hood, siren inside the car, door triggers, hood trigger and trunk trigger along with a radar sensor to trigger the alarm if my windows are down and someone reaches into the car. installed a backup battery and have the alarm tucked away hard to reach area. We were able to install the alarm led in the switch panel to turn the headlights on right beside the fog light led in the open spot looks oem.
The remote start being a manual has a special sequence where the alarm needs to see you hit the brake and pull the ebrake. Then click remote start on the remote and exit the car and hit lock. if the sequence is followed then the car will start. we were not able to hook up the defrost as it needs a 6 volt and is probably controlled through the can bus system. they do not make a bypass for our car specifically and need to use the universal bypass where i loose the key. My installer believes at the CES they will come out with a module that will work with the newer systems and be able to trigger defrost and not have to give up our key. At the same time i got my gps mirror installed
http://www.speedcheetah.com/scshop/section.php?xSec=24
hard wire the radar detector, install the laser jammer
http://www.laser-interceptorusa.com/index2.html
i plan to go back on saturday to finalize the installation, install my bluetooth handsfree kit, and my HID ballast. I got a tint strip on the windshield but it is too low and they are planning to rip it off and re do it to my specs.
