Old Dec 15, 2008 | 09:28 AM
amx1397
Default Re: Longer lug bolts for spacers......HELP !
I think we have the ball end as far as length, remove a wheel push the factory bolt into the wheel and hold it tight and see how much you have sticking through, then do the same with the spacers on the wheel you are tring to put on. Then you will know if you need longer or shorter lug bolts.
