Old Dec 17, 2008 | 06:22 AM
Goldwing's Avatar
Goldwing
Default Re: 2007 Dead Pedal?
I have also read about the dangers of drilling, but it appears the pedal in the 2007 is attached with a couple bolts. You might check with a dealer - they may have a diagram showing installation. Adhesive may work, but not on the carpet.
Suggestion: find out from the dealer if the pedal is secured by screws or nuts/bolts - then find someone with a 2007-08 and remove and measure. The reason I say nuts/bolts is I would be concerned that if the nut is not welded to the bottom of the panel it could fall off and be a bear to replace.
Possibly one of the other members has already bought and installed and can provide a better tip.
