Re: Is our engine EXACTLY the same as the SLK32???
Our intakes, however, are crimped towards the throttle body. So the truth is we do have less power than the SLK32, but its not because of the actual engine, its because of the intake more than anything.
I've also read we might have a slightly less aggressive computer tune. Might be true. Probably not.
I've also read we have a slightly less aggressive cam grind than the SLK32 and C32. I really doubt this, however, because that would be a huge waste of research $$$ to pull something off like that. Much cheaper to just grab the engines off the assembly line as-is.
So, besides the crimps in our stock intakes, the engines and power should be the same.
