Old Dec 18, 2008 | 09:02 PM
NeedsWings's Avatar
NeedsWings
Default Re: Driveline thump solved
to replace carrier bearing
car on hoist, drop the catback
remove heat shield
disconnect shaft at rear end
disconnect support bearing bracket
remove shaft, swap in new support bearing assembly, reinstall.
make note of the support bearing bolt locations on the frame before removing them as the bearing assemble bracket has slotted holes for adjustment.
