Old Dec 19, 2008 | 03:55 AM
maxcichon's Avatar
maxcichon
Talking Re: Silly Headlight Questions
Does the 194 LED's keep the turning signal instrument cluster light on that makes you think you have a burnt out bulb? Do you recommend the 194 as a replacement? What instulation difficulties did you have? Is this a Auto Zone item? Thanks..
  1. Yes, the "Bulb Indicator light came on, and I installed load resistors. I found a place you can order them for ~$8.
  2. I like the color-it matches the HID's very well. I recommend them.
  3. The little buggers are really hard to get at. I'd rather replace headlight bulbs for a living.
  4. I have not seen them at Autozone. Here are some options:
http://www.v-leds.com/Shop/Control/f...m/1/menu_num/2
http://superlumination.com/
http://www.superbrightleds.com/1157.htm
Resistors:
http://www.extremestyling.com/25-Ohm...source=froogle
Hope this helps!
