Old Dec 24, 2008 | 05:39 AM
  #250 (permalink)
Veloce's Avatar
Veloce
Default Re: Biggest stereo bang for the buck mod
Crutchfield says, the cut-off points are 150Hz with a 4 ohm speaker and 75 Hz if you use 8-ohm speakers. Am I too assume that the cut-off is 300Hz if used on our 2 ohm system? And, if so, is this the same as 300 uf as discussed in the thread?
From Crutchfield:
If you like it loud, protect your speakers from bass distortion and enjoy cleaner sound with Bass Blockers. Each Bass Blocker handles up to 50 watts RMS with a 6 dB per octave roll-off. You'll find some general guidelines below for matching Bass Blockers to speaker size. For smaller speakers (3-1/2"s, 4"x6"s, 4"s), the 600 Hz Bass Blockers work well with low-powered systems, while the 800 Hz Blockers are a better choice for high-power applications.
Speaker Size Cut-off Frequency
Read More
6-1/2", 5"x7"/6"x8" — 150 Hz
5", 5-1/4" — 300 Hz
3-1/2", 4", 4"x6" — 600 Hz (low power)
3-1/2", 4", 4"x6" — 800 Hz (high power)
These models come fitted with easy-to-use quick-slide connectors that make installation a cinch. There's no splicing or crimping — just slide one of the Bass Blocker's connectors onto your Crutchfield speaker harness and the other Bass Blocker connector onto your speaker's positive terminal.
Cut-off points are at 4 ohms. If you use 8-ohm speakers, is the cut-off point is twice that?
