Old Dec 26, 2008 | 11:31 AM
007_MI6's Avatar
007_MI6
Default Re: Location of Illumination control module????? Help please ........
Originally Posted by Houston1
When i start my car up and press the brake to put it in gear the BAS/ESP light comes on. it is also causing my brake lights not to work. i was told this could be a problem with the illumination control module. Is this True???
and where is the module located ??????
I just had the brake lights stop working in my car. Was able to trace it to a relay under the hood. Under the hood, drivers side, against the firewall is a black fuse box. Remove both covers, so that you are open to see the two relays towards the firewall. Mine were original, the one towards the outside of the car was black and the one towards the inside was yellow. The yellow one on mine was making a clicking sound, so I replaced it with one from O'Reilly for $16, and problem fixed. Granted I didn't have the warning light come on, but it still sounds like a possible cause.
