Old Jan 1, 2009 | 10:14 AM
oledoc2u
Default Re: Tips or info on brake pad changes or brake fluid change?
You will find everyone has their own ideas for brakes. I will share my info. I went to R1Concepts rotors, drilled only, Axxis ceramic pads, Castrol Synthetic Brake Fluid, and Goodrich steel braided lines. The stock rotors are fine, but I would definetly change pads. The fluid change along with lines is necessary if you are going to be doing a lot of braking, like on a road course. If not, I wouldn't spend the money. The pad change will get rid of the dust issue...
