Thread: Going Vertical
Old Jan 1, 2009 | 09:57 PM
SRT SIX's Avatar
SRT SIX
Default Re: Going Vertical
MI6_007 is 100% correct....It would require major re-engineering to just go straight up (if it is even possible).
The kit goes up about 75% to horizontal. I have seen some that go 90% but it would be impossible to close when seated (probably hard to open all the way while seated as well). There is really no reason to open more than the 75%. That opening allows easy ingress/egress.
Originally Posted by MI6_007
They all go out and then up, unless you have a Lambo (or similarly factory equipped car). The striker plate, A pillar, roof, etc. is designed for a horizontally moving door. The only way to work around this without MAJOR body mods is to go out to the first 'click' and then go up. Once up they look more as though they went straight up. Plus if you dont feel like showing off you could simply open the the door one click and then use normally
