Originally Posted by 240M3SRT
Hey Mopar do you run spacers if so how thick and whats the wheel offset?
Do the tires ever get close to rubbing the 1/4 panel edge or the inner frame?
I use 15mm hubcentric spacers which brings the rims to the exact same offset as OEM and allows me to use the same lug bolts. I cannot remember if the offset is 20mm or 40mm off hand. The tires BARELY rub the undercoating on the inner wheelhouse if I max out the suspension travel(ie going over speedbumps too fast) but other than that there's no issues.
