Old Jan 4, 2009 | 07:47 AM
waldig's Avatar
waldig
Talking Re: What will it take us to reach 11.50's......
Iam not ready to give up on stacked pulleys, as I have my code 3 on the bench for the 178. Right now the 20psig boost is blowing out my upper end due to lack of fuel but that should be corrected soon. At that point I have a plan to use the pair of pulleys to gain even more bottom end, see my present torque curve, cause thats the deal TORQUE.
Code three has the advantage of more RPM on the blower that is good, without buzzing the accessories or idlers so much. Currently even with the LSD I can not get on it hard / fast or I blow off the tires in first and second to a bit with 275 Hoosiers. My times are traction limited but I plan to re distribute some weight to see if I can improve that enough to warrent the changes required to do that.
Be Happy, Woody
See Word Document of chart of second gear at the top rev level for more. Please remenber that this is with the 178 pulley and code 3 and Boost pressure is measured at the Manifold, NOT wye pipe.
File Type: doc
