Re: Factory Hood Modification
Well here are some hood pictures. Inspired by Moparrbust. I'll be painting the vents when I get my other mods together. After getting the underside of the hood sprayed,I'll have to make up some type of rain water deflector. The first picture shows where I adjusted the wood router (With a carbide flat top deburrer installed) to pass over a small area of the rear under brace support thats painted blue. All of the other black looking bracing you see thru the cut out is the saw horses that the hood is laying on.. The last picture shows the underside bracing where I had to slightly notch out. Squirrel Crusher
