Re: Chrysler Coupe Security
Hey ppl, not any help by anyone in this forum but this is what i compiled when we did my car.
its a crossfire 2003
Battery Constant 12v+ Positive Wire (+): Red
Battery Constant 12v+ Positive Wire Location: Ignition Switch Harness
Starter Positive Wire (+): Purple
Starter Positive Wire Location: Ignition Switch Harness
Ignition Positive Wire (+): Pink/Red
Ignition Positive Wire Location: Ignition Switch Harness
Second Ignition Positive Wire (+): Pink/Yellow
Second Ignition Positive Wire Location: Ignition Switch Harness
Accessory Positive Wire (+): Pink/Dark Green
Accessory Positive Wire Location: Ignition Switch Harness
Parking Light Positive Wire (+): Gray/Black and Gray/Red (Use Both). The parking lights on this vehicle use a 2-wire system and will require an extra relay part.
Parking Light Positive Wire Location: At Illumination Control Module. The illumination control module is part of the headlight switch.
Power Door Lock Negative Wire (-): Blue
Power Door Lock Negative Wire Location: In Drivers Kick Panel, Door Harness
Power Door Unlock Negative Wire (-): Black
Power Door Unlock Negative Wire Location: In Drivers Kick Panel, Door Harness
Door Trigger Negative Wire (-): Brown/Gray and Brown/Pink (Use Both). This vehicle has 2 door trigger wires, when connecting to an alarm system use both wires and diode isolate.
Door Trigger Negative Wire Location: At Security System Module. The security system module is located is on the right rear floor of the luggage compartment.
Domelight Supervision Wire: Brown/Gray (Requires Relay)
Domelight Supervision Wire Location: At Security System Module. The security system module is located is on the right rear floor of the luggage compartment.
Horn Negative Positive Wire (+): Black/Pink
Horn Negative Positive Wire Location: At Horns or at the Relay Control Module. The relay control module is located in the control module box next to the battery under the hood.
Tachometer Wire Negative Wire (-): The tach wire is located at the ignition coil use a wire that is not black/dark green or black/yellow.
Tachometer Wire Negative Wire Location: At Ignition Coil
Brake Light Positive Wire (+): Black/Red
Brake Light Positive Wire Location: At Relay Control Module. The relay control module is located in the control module box next to the battery under the hood.
Factory Alarm Disarm Wire (-): Disarms With Unlock
Factory Alarm Disarm Wire Location: N/A
