Originally Posted by corfire
Here's a link to my installation of a back-up cam I installed from Costco. I called the manufacturer about the durability of the cam being turned on all of the time with the ignition. They stated that with these less expensive cams it is not recommended, because they will not last as long as more expensive ones made for constant use. So, mine is set up to operated only when the back-up lights are on.
I missed your link.
I should have checked on the brand name before I posted. I don't see it on the Sam's page or Costco. Looking on eBay, there are many different types. Things to consider:
1. License plate bracket mounting is simple - just make sure there is either a tilt mecahnism on the camera or (as in my case), the camera can be mounted at a slight angle.
2. The camera is connected to a small transceiver. The transaceiver is spliced into a reverse light in rear brake light housing. The monitor plugs into a cig. lighter.
3. Don't fret over "Night Vision". The reverse lights are plenty bright for these little cameras.
4. The sun visors can't hold squat, let alone a 7" monitor. A thin flat screen that is wider is better for attaching to glove box than a smaller, thicker screen. I'd rather have it on the glove box than on top of the dash.
5. Some newer models have GPS and monitor in one unit. Pretty cool if you don't have GPS already.
