181 pulley responsible for belt rib cutting problem
Jan 10, 2009 | 06:05 PM
15
permalink
waldig
Feb 2008
4,508
34
VA
Re: 181 pulley responsible for belt rib cutting problem
Woah Dude halt and stop like. This is how I got my crankshaft BENT and were not playing. Took me 5 hours to straighten the 0.090" on the snout. YOu are in a dangerous area. I had the same thing and there is real danger ahead. I wrote and SPOKE to Jerry about this THEN and finally went ahead and cut the pulley shaft down 0.191" to get the belt in alignment.
I could not be more moved than if I were called out for making technical errors.
I will try to locate the photos to show my issue. You know that my pulley flew off partially due to over heating during autocross which causes severe NOSE - DIVES when the engine shut down, and thus my cooling quest(s). Iam now using the steel 178 ASP which is a welded up design now. We need to talk and understand this. Sorry for the issues and that I have what I THOUGHT WAS A UNIQUE problem.
W
O DY MY photos from a while ago.
waldig
View Public Profile
Send a private message to waldig
Find all posts by waldig
