Old Jan 10, 2009 | 08:56 PM
corfire's Avatar
corfire
Default Re: OK are you ready for this one
Buy a good tire plug kit and a good pair of needle nose pliers.
If the situation occurs you can remove the object from the tire and install the plug.
Then use your tire inflater to fill the tire back up with air.
This can usually be a permanent fix in most cases.
I carry a tire plug kit just as you recommend. However, I spent several years in Germany, and interestingly these plugs were not allowed as a tire shop repair there. They only used an inside patch. Apparently, they felt that the plugs could fail during the high speed driving that is allowed over there?
