Originally Posted by Montana Crossfire
Are you planning on an injector upgrade?
I do know that even with an accurate tune you stand a good chance of leaning out at 23lbs or higher.
Good luck,
Mike
If it is needed, absolutely! I am going to do some testing with it as other people have tried. I am not giving up on the idea yet. Although my thinking is at this point, with the larger intake Mani's, my boost wouldn't be hitting max. On a stock setup, this may be the case, but I did notice a drop in boost when I installed the NW mani's....Then again, I could be totally wrong. :P
