Old Jan 12, 2009 | 05:42 PM
oledoc2u
Default Re: Question for the North
if you really want someway to heat your car, then a circulating heater is better than a block heater, and you can adapt one to any car. I doubt anyone makes a block heater for our cars. A circulating heater simply is mounted inline on the heater hoses. Simply circulates warm water through your cooling system and heater core...you will even have a warm car when you start it up. Most modern day cars will start in below zero weather if your battery is up to snuff without a heater of any kind....hope this helps...
