Old Jan 13, 2009 | 11:53 AM
  #56 (permalink)
tighed1's Avatar
tighed1
Default Re: 181 pulley responsible for belt rib cutting problem
I thought I had covered most of these points in post #50, did you read it or did you come to similar conclusions separately?
Some of your points are incorrect though and could not happen as you state without a lot of belt damage. Hint, ribs are not near to .088 wide.
A post after my #50 has proved what I said about ignoring idler problems, which was raised by another claiming to have solved the problem.
I base my ideas on years of background in engineering and a detachment from the problem, I am not some old f**t flapping his gums as some on this site are prone to do.
I wrote about the bearing problems earlier and I was pooh poohed by someone who was going to solve the problem even when I said he was completely wrong, what became of that solution .... ZIP
180, 180, 180! There you go getting upset over nothing, again!
