Old Jan 14, 2009 | 02:10 AM
SLK32Germany's Avatar
SLK32Germany
Default Re: The three magic wishes, #1
Originally Posted by waldig
The Code 3 pulley will be added and tested before I change anything to see how “over 20 PSIG operation” looks. Also I what to find out what is the max boost attainable with stacked pulleys.
This is a project in process and I am reporting the ups and downs for the general enlighten and technical information. Its been interesting; but to be useful, the boost modification of the fuel regulator needs
better control.
The data logger shows the F/A being real rich as the fuel pressure is being raised from 60 up to about 72 psig. The vertical line shows the F/A rising to about 13 and a boost of almost 20 PSIG Boost.
Be Happy, Woody
Woody, thank you very much for your Testing and sharing the datalogs with us!! What would be also interesting is a datalog from the TIMING-Advance Curve and how the IATs respond to driving under boost. I wish you all the best and good luck with your testing!!
