Old Jan 14, 2009 | 06:14 AM
SRTpowa's Avatar
SRTpowa
Default Re: The three magic wishes, #1
Originally Posted by Forza1
How consistent is this mod?
At first impression, it sounds like we should do the fuel mod, and then carefully lean out the ECU tables to compensate so it is not as rich.
However if the fuel mod fluctuates results depending on variables(weather, for instance), then it would seem to risky to lean the ECU out so much as to compensate.
Ideas?
I was thinking that same thing last night when I read this. Get the extra fuel there with this mod then tune it where you want it. As you said though, it needs to be a somewhat consistant increase, or else it wouldn't work.
