Old Jan 15, 2009 | 01:39 AM
Mimi05SRT6's Avatar
Mimi05SRT6
Default Everything you need to know about Methanol Injection
But were afraid to ask! A great writeup from Snow Performance!
Methanol/Water Injection FAQ
1. What are the benefits of Water/Methanol injection?
1. Low cost - where else can you get up to 60HP for $299.
2. More power than other means of detonation control.
3. Efficiency - leaner air fuel ratio can be utilized for normal operation.
4. Greatly increases air charge densities for huge horesepower increases.
2. Do I need an IntercoolerA "radiator for air" that absorbs intake air heat to cool down the hot air charge from the turbo. There are several types of I/C's but this isn't the pace to discuss them. with Water/Methanol injection?
Up to approximately 20 psi boost, water/methanol injection will provide all the density increase/detonation control needed in most applications. Of course, Intercooling and water/methanol injection would provide even greater benefits especially beyond 20 psi boost. Most air-to-air IntercoolerA "radiator for air" that absorbs intake air heat to cool down the hot air charge from the turbo. There are several types of I/C's but this isn't the pace to discuss them.s are only 50-65% efficient. That means for example, that with 11psi boost and its 120°f air charge temperature increase, an IntercoolerA "radiator for air" that absorbs intake air heat to cool down the hot air charge from the turbo. There are several types of I/C's but this isn't the pace to discuss them. reduces the air charge temperature only 60 degrees. Also, an IntercoolerA "radiator for air" that absorbs intake air heat to cool down the hot air charge from the turbo. There are several types of I/C's but this isn't the pace to discuss them. will reduce boost 2 - 4 psi. on average.
3. Why not use a windshield washer pump?
Water/Methanol must be injected at above 50psi to properly atomize. Lower than 50psi causes greatly reduced air charge cooling as the result of larger droplets and their reduced total surface area.
4. Why methanol?
Methanol is a high octane fuel that is extremely resistant to detonation with an excellent cost/benefit ratio. ($1.50 - $2.00 per gallon.) Its high latent heat of vaporization also makes it an excellent air charge cooler which means a denser mixture and more horsepower. Because of these facts, it is a better anti-detonant than ethanol or iso-propanol although they will work in a pinch. It has however only about 60% of the energy content of gasoline by volume so about twice as much is used to make similar power if used as a straight fuel. It is extremely toxic and should be handled with rubber gloves in well ventilated areas only. Care should be taken to avoid skin contact.
5. How much Water/Methanol?
To prevent detonation, the ratio of Water/Methanol to gasoline is roughly 1 to 5 in gasoline applications- 1 to 4 in diesel. In practice, you give it as much water / methanol as it takes to eliminate detonation without quenching combustion. The amount depends on the onset RPM of injection, the octane of the gasoline, fuel/air ratio, cylinder head type, even the weather conditions. Your engine is actually pretty tolerant of extra water vapor, you will know it's too much when the engine misses and loses power.
6. Where can I purchase Methanol?
Methanol can generally be purchased where racing fuels are sold. Also, most gas line dryers like "Heat" are simply Methanol. Suppliers of industrial chemicals can also supply Methanol usually at a higher price than fuel suppliers. If all else fails, most windshield washer fluids are up to 40% Methanol and 58% water. Methanol can be purchased on the web at www.worldwideracingfuels.com and www.hiperfuels.com .
7. How long will a tank (2 qts.) last?
In high boost/high horsepower application, a full blast 1/4 mile run will utilize as much as 1/8 tank. A larger tank should be considered if over 9psi boost is utilized in road racing where a tank can be used in as few as 6 - 2 mile/ full tilt laps. Under normal street use in a 400 HP Mustang, a tank usually lasts about 500 miles. Two reservoirs can be used for 1-gal total capacity if desired.Turbo's use more qty. and usually utilize the existing windshield washer reservoir (over 4 qts. in most cases) or the new 8-gal reservoir upgrade. More will always be used when the system is first installed, less when the novelty wears off.
8. Can I use windshield washer fluid?
Although most contain some glycol and detergent, most windshield washer fluids are up to 50% alcohol (methanol, ethanol, isopropanol) and make an excellent Boost Cooler. Try to find one that indicates "contains methanol".
9. At what boost level do I introduce Water/Methanol?
Centrifugal superchargers/large turbos: Generally, at 50% of peak boost the recommended quantity should be introduced. Positive displacement superchargers/ fast spooling turbos: injection should occur at or near peak boost to avoid combustion quench since peak boost occurs so fast.
10. What ratio of Water/Methanol is recommended?
A 50/50 ratio is recommended. This has been demonstrated to be the best for charge/air cooling, excellent detonation control, and controlling cylinder temperature. This includes diesel applications where water conditions the combustion of the methanol so combustion timing isn't affected.
11. Many recommend Denso Iridium spark plugs in boosted applications. Will these work also with water/methanol injection?
Denso Iridium spark plugs are highly recommended with the Boost Cooler. Iridiums, with their low firing thresholds and intense spark, allow for larger quantities to be injected sooner without misfiring. This allows for more cooling of the intake air. If you have a misfiring problem, nine times out of ten, Iridiums will clear it up.
