Old Sep 30, 2004 | 11:03 AM
C_Plunkett's Avatar
C_Plunkett
Default
According to the service manual, you have to remove the lower piece (across the bottom of the window) first. This is done be removing a screw inside the handle to close the hatch. The panel should then just pop off. This exposes one screw on each of the upper pieces (beside the window). Take the screws out and then those pieces should pop off.
