Re: Stacked pulley is not for me...
Boost mod 1.00:
yes a 1/4" line to the regulator center fitting and to the manifold,
This first step, is crude and Iam ordering components to allow my data logger to output a signal controlled by the F/A value. I hope to use this signal to modulate pressure to the fuel regulator and thus control the rail pressure DYNAMICALLY. Should be interesting, BUT ordering things takes LONG TIME BOOM BOOM and my activities will be stalled till then. PUN intended.
When I get the parts, I plan to control the boost air pressure to the regulator by switching on and off the boost pressure line. Thus adjusting the average pressure in accord with the F/A value I select.
PS It shows that the injectors with a constant 60psig fuel pressure DIFFERENTIAL can flow all the fuel we need for a CRAZY stacked pulley setup.
I sent you another PM re boost number.
Woody
Photos tomorrow, camera got set to TIFF format, by error......
