Old Jan 15, 2009 | 10:24 PM
  #99 (permalink)
onehundred80
Default Re: 181 pulley responsible for belt rib cutting problem
Onehundred80...Yes I'm reading your thought's. I'll be purchasing a 185 pully from someone in about a month. So why the tip for choosing ASP pulley's? I need guidence for making the correct brand choice. Thanks.. Squirrel Crusher
The reason is simplicity. The simplest part is a one piece pulley. The simplest part with a damper is a three piece pulley, consisting of a hub, connected by a damping medium to the ribbed portion of the pulley just like the OEM part. The more parts you add, you increase the complexity and troubles. You want a simple pulley, not a Swiss watch.
