Old Jan 16, 2009 | 08:03 AM
sonoronos's Avatar
sonoronos
Default Re: Long Time No See Peeps !!!
Welcome back HDDP.
You'll like the Stohr. John from Trackpedia owned a DSR but unfortunately it burned to the ground:
http://www.trackpedia.com/forums/showthread.php?t=2494
This was in Minnesota @ BIR. The reason for failure was component related - the oil cooler fittings failed - you might want to check yours if your DSR comes with a Setrab cooler - I'm pretty sure Stohr uses a lot of similar components between cars.
I did have a chance to see John's replacement Stohr F1000 run all day. It's not super fast on the straights but on the corners, his telemetry said he was pulling multiple g's.
