Old Jan 20, 2009 | 10:33 AM
rcompart's Avatar
rcompart
Default Re: Install 6 spd manual transmission into SRT6
Originally Posted by apkano
The auto trans is electronically tied into the PCM, just part of the Mercedes security system. You will need to overcome this, as well as the mechanical tie-in.
HDDP put a SRT6 engine into a 6-speed car. I think you will have the same problems that he did.
You might want to send him a PM or e-mail. Here's a link to his profile page....
https://www.crossfireforum.org/forum/members/hddp.html
Whether you put the 6-speed manual in an SRT6 or an SRT6 engine in a base or limited with a manual, your key, the security control module, ECU and PCM will be the problems that keeps you from getting it done. That is one of the reasons HDDP ended up using a stand alone engine computer. The key sends it's unique, VIN specific code to the SCM(security control module), the SCM verifies the code against the ECU and the PCM by query. If the ECU or PCM don't send back the correct code to the security control module, it doesn't send the all clear and the engine will not fire.
