Old Jan 21, 2009 | 04:15 PM
  #106 (permalink)
boohooramblers's Avatar
boohooramblers
Default Re: 181 pulley responsible for belt rib cutting problem
Originally Posted by tighed1
$20 and five days later the SRT is back on the road and running perfectly.
CP lines up and the belt is running true on the other pulleys as I expected.
I did have some belt slippage at higher boost in 2nd and 3rd gears. Hoping that the belt will settle in and the slippage will go away.
Glad to hear you are up and running again.
Although it is unlikely that there would be an issue if the trimmed snout was done perfectly, did you have the pulley put on a balancing machine to make sure there are no balancing issues?
