Thread: Nitrous
Old Jan 22, 2009 | 02:40 PM
psuperti's Avatar
psuperti
Default Re: Nitrous
Originally Posted by davidjacob
Hi, I was wondering if someone knew a little bit about nitrous... I was told that we cant pass 44% of the car's horsepower. Is that true? so it would give me approximately 300 hp when on the nitrous. Can it me damageable for the engine or tranmission or clutch? Can it withstand all that boost? Would I need something (ex: a higher output gas pump) to modify so the car runs fine? By the way, I have a limited.
Thanks
David
You don't need a better fuel pump because a shot of 75 hp would be a wet nitrous kit. Meaning you are mixing gas and nitrous, therefore the car will get the proper fuel amount while you spray. If your car is stock 75 hp is the max. Also, if you opened your air intake with the needswing CAI in combination with the tune you are most likely already lean. That's why I got the injectors from TVT.
Please take at look at my nitrous article in my web site.
ps. forget the 44% it depends on the car.
