Old Jan 22, 2009 | 07:05 PM
The Beep's Avatar
The Beep
Default Re: Loud buzzing. No start.
First I would take the battery out, use a reliable charger and see if the battery will take a charge. Once charged, take it to Autozone/ Pepboys, somewhere they can check it out with a load test. If battery passes the test, then you need to check alternator output/etc. This is just a start.
James
Everything was perfectly fine when I put it away. It's an 05 so the battery is 4 years old. It is stored outside and we've had a number of -25 F nights and a bunch of days where it never got above 0.
My guess is that battery is completely hosed.
Are the Die Hards any good these days?
