Old Jan 22, 2009 | 10:06 PM
j-fire's Avatar
j-fire
Default Re: Are all of these symptoms of the IC water pump?
i had something like this, but it turned out to be my sprint-booster failed.
the code that came up was an 'throttle-pedal' failure, so the benz dealership wanted to order me a new pedal. i told them to just disconnect the sprint booster and clean up the pedal and sensor already on there.
lo-and-behold, worked like a charm. if you get a code for the throttle-pedal, just take it apart and clean it up.
make sure you get the ECU scanned. don't waste so much time at the dealer!
