Old Jan 22, 2009 | 11:19 PM
cruzinquick's Avatar
cruzinquick
Default Re: Are all of these symptoms of the IC water pump?
Originally Posted by paul1612
I purchased a SRT6 in December 08 with 19,000 miles on the odometer. I plan to take a few roadtrips of about 400 or 500 miles in sometimes relativley remote areas. Do all IC pumps fail at roughly the same mileage? Should I just replace it now or is there a good possibilty that the pump will last the life of the car? I know it would not leave me stranded, just hate to have to limp back home.
Most failed because the cars sat 2 years on a dock somewhere between the US and Germany. If yours has not been idle then you should be good. It's precautionary and doesn't leave you stranded if it does go out. I changed my stock for basically the stock bosch pump. It still worked great, but my car did sit for 2 years and only had 212 miles when I got it. So was just in case so I didn't waste any trips to the track.
