After a business lunch today, and the first time driving the car since Thanksgiving, I decided to install my Needswings Intake Manifolds and Y-Pipe. Install is straight forward and very easy. Rob includes all the new bolts you need and 4 extras needed if you use plenum spacers (which i did). His gaskets are perfectly cut and will seal the spacer a lot better then the stock ones. Here are a few pictures.
The pictures does not show it to well, but the manifolds are quite a bit larger
This shows the height difference and extra volume
Heres the manifolds installed
And the Needswings CAI back on.... Stock pulley/front engine cover does rub on the drivers side manifold so I added it to my Box-O-Stock parts
