Old Jan 25, 2009 | 07:02 PM
SRT-6 Steve's Avatar
SRT-6 Steve
Default Re: Finally... My Needswings Manifold are installed!
Did you happen to check real close to see how tight your hood with the insulation is when closed? The reason I ask is that mine is very tight just with the larger spacers and stock mani's. It burries itself into the hood insulation. You could trim the insulation a bit. You may want to check this so you don't put undo pressure upward on your hood and cause a slight buldge.
Steve
