Old Jan 26, 2009 | 04:46 AM
crossfirefrank's Avatar
crossfirefrank
Default Re: Convertable problem help!!
I assume your talking about your rear deck lid. I had this happened once and my rear window went down before the back deck lid and it ended up resting on the rear window. How I solved the problem was to raise the deck lid all the way back up to it's upright position with the ignition off. There must be a position switch that has to made for it to function, anyway with it in the upright position you should be able to go in turn the ingnition on and either lower or raise the top. good luck.
