Old Jan 26, 2009 | 08:13 AM
PAULW's Avatar
PAULW
Default Re: Convertible problem help!!
crossfirefrank is correct. Sometimes you can just turn the key off and back on and it will re-activate the system. If you stop the process in the middle of going up or down (which I have done several times to clean) it will sometimes not respond to the switch and usually I only have to cycle the key to make it start back up and if that does not work just turn the key off, pull it all the way up and try it again.
