Thread: slowed down
Old Jan 30, 2009 | 01:55 PM
cruzinquick's Avatar
cruzinquick
Default Re: slowed down
Remember DA of any difference will yield you a different time. You can't judge just by temps. It can be 70 degrees on both days but one has alot higher humidity, then your DA will be much higher and you will be slower.
For example, someone gets a CAI and runs a 12.85 in 1200' DA, then gets a pulley and tune and runs 12.45 in 3800' DA. Comes back a little dissapointed and says needs drag radials to make it hook. When in 1200' DA just the pulley alone would have yielded a 12.45. Now your just comparing 60' foot times. That's even more crucial of the DA, tires, and track prep. Best advice is to get your baseline runs or 60's with DA on each of your runs, not just the night. This little gadget will help. www.biondoracing.com look up the performaire 2 or PA2 or just have someone ask the tower before or after a run.
