The last six digits of the VIN are the build number. Your's is 19647. It is a fairly late build for an '04, so any early bugs shouldn't be a problem for you.
The right and left lights are standing lights for when you are parked on the side of the road. I think that is a European thing.
The warning light sounds like the low tire pressure light. You need to check the pressures. They should be 33 psi rear, 32 psi front.
