Old Feb 2, 2009 | 05:14 PM
  #89 (permalink)
wocar's Avatar
wocar
Default Re: Mercedes Air Box W/CAI
Originally Posted by jbomar
SACETORNC,
I can get you the part numbers once I get back in town from the holidays...I am very impressed with the larger K&N filters....nearly twice as big as XFire stock.
As far as the tubes go, they stop right beside the radiator. I removed the factory tubes and their mounts located beside the radiator. After the holidays I'm going to get a few pcs of tube and run these past the radiator to insure the intake comes from completely in front off the grill. Will post whatever I work out.
So far I really like what this TVT kit is giving me!
Go back and review this thread the tubes stop at the ducts beside the radiator. They do not go past the radiator. If you took a picture with the grill removed all you would see is the original duct If you want to go past the radiator you will need to remove or modify the air duct. You would also need to add to the aluminum tubing supplied with this kit.
