Old Feb 2, 2009 | 10:47 PM
  #90 (permalink)
TVT_DESIGN
Guest
Posts: n/a
Default Re: Mercedes Air Box W/CAI
Originally Posted by wocar
Go back and review this thread the tubes stop at the ducts beside the radiator. They do not go past the radiator. If you took a picture with the grill removed all you would see is the original duct If you want to go past the radiator you will need to remove or modify the air duct. You would also need to add to the aluminum tubing supplied with this kit.
A 3" piece of silicon will lead the flow right through the radiator.
