Re: Difficulty Starting + Solution & Dealer Fix
Banej, that sounds like the crank positon sensor setting off the CEL. I had a similar issue and used a OBDII reader to pull the code. P0335 I believe. The crank position sensor CEL will clear if the car starts up fine 3 times after it trips.
MikeR
