Old Feb 4, 2009 | 11:41 AM
banej's Avatar
banej
Default Re: Difficulty Starting + Solution & Dealer Fix
Originally Posted by brhertel
MikeR, does the crank position sensor fault allow the car to crank? I was under the impression that the crank position sensor issue made the car not even crank. The issue I am having is the engine cranks at full speed, but does not catch, as if it has no fuel.. Also, I never got a CEL.
The main reason I ask is because if this fuel pump doesn't do it, I want a backup plan to talk over with the dealer
yes i think you may be right because the crank sensor wouldn't let the car crank but in our case it the car cranks every time but no start. fuel pump makes more sense but i just don't get why the temperature change of the engine makes a difference.
