Old Feb 4, 2009 | 06:17 PM
Kurts's Avatar
Kurts
Default Re: Check Engine Light
You could try these guys:
http://www.lkqonline.com/
Or, if it is the Relay Control Module, it seems that the problem, at least in a few cases, has been cold solder joints. Some one good with a soldering iron merely re-melts all of the connections on the back of the circuit board. Do a search and read more.
Since you're in Alabama, and a sterling fellow, I would volunteer to do the work. In Auburn!
And I would like to hear your exhaust!
PM me if you want...
Don, Max is right; if it is intermittent it could certainly be lousy solder joints &, most of the time, they're rather easy to spot. A touch-up on any questionable looking ones & voila', you might just be good to go!
Also, try to re-seat every stinkin' connector on the board & make sure it's in there snug.
Intermittent problems are the toughest to find so start with the simple fixes first .
