Thread: Stall Converter
Old Feb 5, 2009 | 03:22 AM
SLK32Germany's Avatar
SLK32Germany
Default Re: Stall Converter
There is a lot of talk about High stall converters on the forums. Do you get Advantages from them also in the higher gears? Will there be a negative effect at high RPMs, for example the car fall on its face at higher RPM? What are the negative effects in general? Thanks.
