Old Feb 5, 2009 | 07:54 AM
onehundred80
Default Re: traction control
Originally Posted by 6speed05fire
how do i get rid of traction control??? do i pull a fuse or what?
If you must drive in snow I find these rules to be worth following because if the other guy is out of control you have to be in control.
1, Snow/Ice tires, you will feel the difference.
2, Some reasonable weight in the trunk, 100# or so.
3, Traction Control ON, unless you are really stuck when you switch it off to avoid overheating the brakes.
4, Keep the revs down, avoid rapid acceleration and braking.
5, Windows clean and free of snow, if someone is going to hit you it is best to know about it.
6, Pull away in second gear.
7, The golden rule, if it is really bad, do not go out.
