Old Feb 5, 2009 | 08:37 AM
Paul Bosslet's Avatar
Paul Bosslet
Default Re: HELP with noise from behind the dashboard (AC Unit)
When I partially removed the bottom panel that hides the fan motor, there were alot of twigs and leaves and other debris that had to be cleaned out. So change the filter, clean out all the debris and everything should quiet down. Good luck.
