bought front and rear camber kits
After living with my lowered Crossfire for a year the only problem I encountered is uneven tire wear which has increased in the front and is very bad in the rear. I was hoping that a toe adjustment might help and had the car on the alignment rack this morning. toe and caster were all correct but camber was obviosuly out enough to give me me tire wear problems. I know some on here have not had this problem after lowering a car but my rear tires are only six months old and still look new on the outer tread but just started showing cords in the inside edge. My fronts also wear the inside edge but not at all like the rear.
I purchased the front camber bolts from the dealer and have ordered the KMAC kit for the rear. I will be installing myself and then back to the alignment shop.
